FAST or LS6 Question
Can someone post up a picture of a closeup of their injectors. For some reason I dont think the injectors are not in far enough. They are all down the same and the rail is tightened, but you can see the silver part on the bottom of the injector.
I dont remember them showing this much. I sprayed carb cleaner to see if they were letting air through but there was no change. I'm just a little concerned. I tried the search, but all I could find was pictures with the entire engine.
to be honest i really dont know about that but they should be, ive never heard about chevy changing rails and injectors on LS1's but you have a 98 and im a 99 they should be the same!!
my injectors move pretty easy but do have some resistance(that is normal). If they don't move the rail is way too tight. Make sure you have the screws coming from the side of the fuel rail tight after you tighten the main fuel rail bolts(rail to manifold).
