Y-Pipe to fit between QTP's and Magnaflow?
Anyone make one that will work? My exhaust shop around here is closed till June 11th and i was wondering if there is one i can order that will fit, maybe with some ground clearance this time, unlike that damn qtp y.
Originally Posted by joblo1978
Kooks will work I believe.
https://ls1tech.com/forums/generation-iii-external-engine/682400-qtp-headers-kooks-y-pipe-spohn-solid-motor-mounts.html
Ihave kooks and there y-pipe with a maganaflow catback exhaust. I had to cut off the piece of pipe that goes into the I-pipe. Then shave off 3-4 inches and have it reweled. The rearson I cut it off was because the y and I were connecting at to low of an angle.
I have QTP's, a Pacesetter Y, and the stock CME with a Magnaflow muffler. My mechanic installed the Y for me when I had the clutch done since he had to chop the old exhaust off to get the trans out. To make things easier, he installed some flex couplers and secured the exhaust so there wouldn't be any floor banging issues. The flex couplers allow the engine to move and saved me from having to install poly mounts.
Pics @ http://www.motownmuscle.com/forums/s...ad.php?t=48204
