WS6 vs SS Air lid base, have you noticed?....
Old 05-29-2007, 01:21 PM
nrmustang's Avatar
Default WS6 vs SS Air lid base, have you noticed?....
I was looking at some pictures between a WS6 and my SS and noticed that that TA's air lid base has a much larger opening below the filter.
Has anyone swapped these out before? Is there a performance gain (even minimal) ?
Or is it a clearance issue based on the hoods?
Old 05-29-2007, 03:55 PM
soulless's Avatar
I always thought they were the same. Are you sure you are not loking at the FRA?
Old 05-29-2007, 04:14 PM
Sunset01TA's Avatar
they are different the ss is the same as a TA formula or z28.
The WS6 is much larger opening.
Old 05-29-2007, 04:15 PM
nrmustang's Avatar
So will it fit the SS, or is the hood too low?
Old 05-29-2007, 06:51 PM
SS4Luck's Avatar
no it wont clear the SS hood, ive seen it done with the ultra Z hood but the guy that did it said it didnt work on his stock hood
Old 05-29-2007, 06:56 PM
Almostryan3's Avatar
The volant dual Y cone fits under a stock Z28 hood
Old 05-30-2007, 12:33 AM
nrmustang's Avatar
Thanks, that what I figured. Did he say whether it was worth it to swap it out?
Old 05-30-2007, 12:12 PM
Cahill93Z28's Avatar
i doubt there is any real gain.
Old 05-30-2007, 10:05 PM
INMY01TA's Avatar
Old 06-01-2007, 12:26 AM
WILWAXU's Avatar
WS6 is a little over twice as tall opening as the rest of the f-body radiator support/lower airbox's
Old 06-01-2007, 08:56 AM
Pontiacerator
RevGTO's Avatar
It's built that way to capture the incoming cool air from the scoops. The air exits up high over the top of the baffles out of the backside of the hood brace, IIRC.
