Calling 00-02 Camaro SS
When installing a Direct Flo Air lid where did you route the air tube and Breather filter? Mine is tucked next to the abs box on the drivers side. I want to shorten the hose and attach it to the radiator support.
Any better ways of attaching it? Thanks
Re: Calling 00-02 Camaro SS
i ziptied mine to the end of the radiator..... the right side when u are facing the engine from the front of the car. Tucked up nice, you can barely notice it.
!LS1 11 Second Club
Behind the Headlight in my case also, but I've seen a bunch of configurations. If there is a "correct" place to put it, I'd like to know also.
when i had the air pump still, i mounted mine to that ground wire on the drivers side of the radiator. zip tied it to it. cut off enough hose and it sat straight up
Moderator
My lid came with a hose extension so it looks kinda stock.
But you might oughtta follow that hose as far back as you
can, cut it off and put the breather filter where it won't
be an eyesore. Not like you really want to see that hose
anyway.
anyway.
