Headers & Exhaust: lift tools needed?
Wondering for you do it your-self types.. what lift set up did you use to get it done?
Im wondering if the 18 inch jacks and stands will suffice.. Im debating about trying to get a 30 inch jack and some high lift stands.
Chuckles.. ideally wouldnt a 2 post lift just be sweet hehe
Just dont know if itll give me enough room.. shrugs... and I dont think Ill feel safe putting 2x4/6 or whatever under the stands and jack..
you just need to have the car off the ground enough to be able to move the headers around. i had to take off the steering shaft and then point the drivers side header straight up to get it to go.... i was also on a lift so not sure how much clearance you will need maybe 2 feet
when i put mine on the first time i used jack stands and it was a super pain in the ***. i had to quit many tie to keep from getting frustrated. then after all that my flange was warped on the header so i took it to the hobby shop on base here. had the headers off fixed and back on in an hour. if you can get a lift and a 10mm ratchet wrench. it will save you a **** load of time
i stacked cinderblocks underneath the jackstands and jack and got it pretty high in the air. I gave the car a good shake to make sure it was sturdy before i got to workin though. didnt shake one bit...
mm i was thinking of gtting the wood, not sure if id trust thecindrblocks,.. i think i might worry about a crack or something
.. i ended up getting the 3 ton combo craftsman combo from sears and going to go uner there and play around.
My main thing is I am going in there to trouble shoot some rattle coming from somewhere between the hi flow cts and the muffler.
I am wondering if I should get 4 jack stands and lift te whole car up as opposed to 2.. shrugs
I wouldn't worry about the car shaking, I would worry about the cinder blocks cracking in half!
But I easily did a header swap on my Camaro with a set of jackstands.
If you need more clearance to get the stock manifolds out or the headers up and into the engine bay, just place your jack under the center of the K-member with a block of wood between, and you can easily get another few inches without the tirtes even leaving the ramps.
