finishing my new motor, need some advices, pics! help
i a just about to finish my motor,
couple of questions,
the heat pipe that goes between the heads, it had to go because of the fast intake, what are you guys doin instead?
i bougth the Fast fuel rails, i am not to happy with them, where the he#l does the fuel regulator go? and where does the solinoid go? i am not figureing this out myself, does the adapter kit have thing to make it work?
help please =( would be great if someone had pics
By heat pipe do you mean the front coolant pipe? If so then you can't just ditch it. You have to buy the LS6 front coolant pipe with the rear pipe blockoffs. My LS6 front pipe didn't allow the FAST to bolt all the way down in the front but I just lightly tapped the front of it with a hammer in the center to get the pipe to bend down towards the block...problem solved.
Everyone else is pretty on target w/ the coolent piping. The thing in your pics is a device that helps regulate the fuel between the two rails if Im not mistaken. The auctual pressure regulator is in the tank right beside the pump. I think that if you just use the crossover piping that 1320 killer has you should be good. Im not an expert w/ fuel systems though so if Im mistaken just post up.
