what gains will I see form an underdrive pulley?
Old 06-05-2007, 01:42 PM
trans99am's Avatar
Default what gains will I see form an underdrive pulley?
just as the title says.... what gains will i see in engine performance? will I see my voltage drop because of less alternator spin? will power steering be affected or a/c? give me the pros and cons of a pulley. thanks
Old 06-05-2007, 01:51 PM
SupermanSS's Avatar
I would like to know also...
Old 06-05-2007, 01:54 PM
silent1's Avatar
I've seen 12rwhp 8rwtq gains. There are alternator pulleys available so you don't lose voltage. P/S and A/C aren't affected much if at all while driving. You'll notice it more at idle/stops.
Old 06-05-2007, 02:21 PM
Ericbigmac83's Avatar
Somebody didnt use the search......
10hp is the most youre really gonna see, You should gain a little bit of gas mileage. They do make overdrive pulleys for the alt. to make up for the underdriven pulley, and a/c and p/s wont be affected much
Old 06-05-2007, 02:29 PM
omcar's Avatar
i experienced a h.p gain in my 2001 formula..It's all part of a "combination" that works for you.
Old 06-05-2007, 03:57 PM
jay_99z's Avatar
It only works for 3 hours a day......... and most people are sleeping during those hours.
When I did the pulley I didn't notice a huge difference. It will help though.
Old 06-05-2007, 04:04 PM
bluehawk2's Avatar
+1 on the combination effect....................It is a combination of the little stuff that eventually gives you a large gain: pulley, lid, ported tb etc.
If you go ahead and get an alternator overdrive pulley, you won't see any bad effects of the underdrive pulley.
