blackwing filter Install
Old 06-06-2007, 06:59 PM
kraemer94's Avatar
Default blackwing filter Install
I just received my blackwing filter. I having issue installing it beleive it or not. It came with a replacement tray. I replaced it and place the filter in. When I went to close the lid (SLP) very hard to close and not a tight seal. Does anyone else have this setup?
Thanks!
Old 06-06-2007, 07:05 PM
styoung's Avatar
you need to push you filter way back so it seals on the lip of the filter. hope that helps
Old 06-06-2007, 07:22 PM
kraemer94's Avatar
Default Blackwing filter
Is the replacement tray really needed.
Old 06-06-2007, 07:32 PM
styoung's Avatar
i know i used mine but it should make a difference i wouldnt think.
Old 06-06-2007, 07:38 PM
kraemer94's Avatar
I'm not having much luck, Might resturn it and get a K&N filter instead. My stock tray and my paper filter fix right flush. But when I install the replacement tray with the blackwing filter it's very hard to close and there are gaps on the sides. The clamp just barely clip down. I wondering if this filter work with the SLP lid.
Old 06-06-2007, 08:04 PM
Bad Blue WS6's Avatar
same thing here,,i just took the tray out,,,gave me about 9 HP,,,,,,,,that part was just me being funny, but i really did just take it out,,,i still dont think it fits perfectly,,but the 4 tabs on the rear of the lid actually go into the slots,,and my rubbing hood/lid stopped as well.
Old 06-06-2007, 08:18 PM
kraemer94's Avatar
Default Blackwing
So you are not using a tray at all? Also or you using a SLP lid?
