WTF? Water Temp Senspr Broke!!!!
Old 06-06-2007, 08:27 PM
01 BERGER CAMARO SS's Avatar
Default WTF? Water Temp Senspr Broke!!!!
I guess i over torqed it and it broke off. The piece that has the treading is still on the head. How would I got about taking it off with out removing the head or do I have to?
Old 06-07-2007, 06:28 AM
LS1-450's Avatar
It may come out w/ a little patience. See if you can drill a little hole in it. I know it's a tight area & the hole can be drilled @ an angle. Just don't go to deep or hit the block. An easy out probably won't fit in the hole. So, see if you can get a left handed hex head screw to fit; maybe even a self tapping screw. You may have to epoxy the scew into the little hole you make (JB quick weld). Then use a wrench on the hex head & unscrew the broken piece. Good-luck
