ASR problem
Old 06-08-2007, 02:25 PM
TheLS1Kid's Avatar
Default ASR problem
I just installed a FAST 90 with a NW 90mm throttle body. The car runs great but my stupid ASR light will not turn off. Even if I hit the switch the light in the dash stays on. I found a thread that someone started because of the same problem, but it just ended. He didnt say what fixed the problem. Does anyone else know what this could be?
Also, does anyone else on here have a K&N FIPK with a FAST 90 and 90mm TB? My air intake sucks loud as hell now. I think it is normal but i could be wrong.
Thanks.
Old 06-08-2007, 05:36 PM
TheLS1Kid's Avatar
Nobody knows??
Old 06-08-2007, 06:44 PM
Switchblade's Avatar
It could be the following
1) Your ASR system has a fault and the computer has stored a code
2) A bad connection on the wheel speed sensor, or the sensor itself is faulty and needs to be replaced.
Best bet would be to retrieve the code from the computer to determine the problem.
Old 06-08-2007, 09:53 PM
dudeman's Avatar
the sucking is probably normal do to the fiant *** throtle body
Old 06-08-2007, 10:02 PM
TheLS1Kid's Avatar
Thanks for the replies guys.
I drove the car for about 10-15 miles and the ASR problem is fine now. The light turned off and now turns on and off with the push of the switch.
I think it just needed to reset itself.
The new intake is awesome, IMO every H/C or big cube car needs one.
