SLP fan switch turns off TCS ???
i recently connected a slp fan switch and my tcs light came on.. is this normal?? does the fan switch also take off the traction control function?
I've had the SLP fan switch in for a couple of years and never had any interaction between the fans and the TCS rocker switch. I do have it mounted right beside but have put ample insulation in there.
Are you sure there isn't a wire shorting against the other switch or similar?
i have no clue ... evrything is sealed fine... no wires are spliced or cut.. when i turned the car on the tcs light stayed on.. and it wouldnt turn off when i would flip the tcs switch either.. so i dont know whats going on
no..im not a novice at car stuff.. i know what i have followed the instructions from slp.. which im calling tommorow.. and my dad is a master tech for gm vehicles.. and tommorow ill get a wiring daigram from the dealership to see what is going on.. just cant understand why my tcs light goes on..
