Alternator probs after heads/cam swap
Started my car last night to fill the coolant after doing my heads/cam swap and found that the alternator was pumping out 18V solid. Prior to doing the swap, it was fine, so I'm wondering if anything could have happened during the swap to make it act up. The only thing that was removed from it (the alt.) was the top wiring harness, the main battery cable was untouched. It may have had a bit of coolant spilled in it from water pump removal, but I don't think that could cause it to spike voltage like that. Any ideas?
