Need an exhaust mount
Old 06-14-2007, 02:52 PM
Hobb3s's Avatar
Default Need an exhaust mount
I'm looking for the one that comes off the of tranny and bolts up to the Y. When I was taking my exhaust off the bracket that bolts to the transmission was cracked and broke into two pieces. I talked to a couple of parts stores and no one carries it or can even provide a part number.
Old 06-14-2007, 09:58 PM
HavATampa's Avatar
Are you talking about the part that bolts to the tranny with the rubber insulator #27 or the metal piece that slides in the rubber insulator and bolts to the pipe #30? Here are the part numbers and descriptions I found. The part number on #27 bracket has either been changed or no longer exist, at least on GMPartsDirect site.
27. BRACKET. CTLTCCONV HNGR. 99-02 F(LS1.MM6) p/n 10284835
30. HANGBR.O'1.TCCONV........ 99-02 F (LSI) . RH p/n 10262319 $8.77
Old 06-14-2007, 11:21 PM
bww3588's Avatar
i got one....PM me if intrested.
Old 06-14-2007, 11:58 PM
Soul TKR's Avatar
your not talking about the mufflex bumpstop are you?
http://mufflex-performance.com/miva/...ct_Code=LS1-HR
Old 06-15-2007, 10:02 AM
PunkNPonys's Avatar
I am missing that same piece. My question is, do we really need that piece? My X-pipe is intalled without it so why cant my y-pipe be installed without it? Does anyone use a ORY without using that bracket?
