Car wont start after headers and mounts =[
I installed pacesetter LT with their y pipe, and prothane mounts. My car cranks but wont fire. I have brand new plugs with brand new MSD wires. The plug on the top of the alternator is plugged in, the hole ontop of the intake manifold is plugged. I cant figure out why it wont start. Coil pack plugs are connected, IAT is connected, MAF is connected. This is kinda frustrating. The rear o2's are not plugged in, but the front o2's are plugged in.
Originally Posted by 5.3LJimmy
Also check the crank position sensor(located behind the starter on the side of the engine). It will not run at all if you accidentally knocked it loose.
exactly the problem, everything is great now. Im terrorizing the neighborhood open header. Thanks everyone.
Originally Posted by mnypitZ
At least that is all you did. I accidently sucked a rag into the intake and bent valves and the car is still not running 3 weeks later.
I bet you had a funny look on your face right after you saw that rag disappear.
