Extensions or Bosch 13111's?
Old 06-20-2007, 11:22 AM
Pontiacerator
RevGTO's Avatar
Default Extensions or Bosch 13111's?
I'm getting ready install my LT's and wondering if I should use extensions or get new Bosch 02 sensors. The stock ones seem to be working fine; the car has 64,000 miles on it. The 13111's would be double the price of extensions, but then again, they'd be brand new. But if the stockers pretty much last forever, why bother? Opinions?
Old 06-20-2007, 11:27 AM
daryl2cb@yahoo.com's Avatar
well, if you have the pacesetters, use thier wires and save some cash on both. If not my vote is for the extensions
Old 06-20-2007, 11:33 AM
WS6NIGHTMARE's Avatar
Im using the Bosch o2's. They work fine for me, and the only time one went out, they are under a 12 month warranty. Some people have problems with them. No matter what if your headers are coated, as the coating on the inside comes off its going to kill one or two.
Old 06-20-2007, 11:35 AM
Tech Resident
ChocoTaco369's Avatar
i was going to get the bosch 13111's, but after investigating the topic and seeing how many people complain about them being lousy, causing the car to run poorly and all kinds of crap (typically associated with EVERYTHING bosch makes), i decided to get 2 24" extensions and run the stock O2's. when they go out, i'll either get another set of AC Delco or those denso ones people rave about.
Old 06-20-2007, 11:49 AM
MannyZ28's Avatar
In my case, the extensions with the stock O2s didn't work well at all, car kept throwing codes. Got rid of the extensions and stock O2s and put in the Boschs and the car has been fine since...no more codes.
Old 06-20-2007, 01:37 PM
1320 killer's Avatar
I just changed mine yesterday and I went witht he bosch 13111. they work great
Old 06-20-2007, 02:00 PM
Dal1as's Avatar
Ditto.
Old 06-20-2007, 02:05 PM
Dal1as's Avatar
Double post. Sight acting up.
Old 06-20-2007, 02:42 PM
Sweet71's Avatar
Deffinitly 13111
Old 06-20-2007, 03:47 PM
LS1TECH Sponsor
badpewter-z's Avatar
extensions (preferabbly the ones that plug in on both sides )or get the stock vette sensors , seen way way to many issues first hand with the bosh sensors, they dont read as fast and can give driveabilty and tuning issues
Old 10-31-2007, 08:28 AM
RedWS6 00's Avatar
For about a year now I've been running LT's, used the stock sensors with extentions. This has been idling fine, the AFR has been good.
About a 2 months ago I change the heads and cam. After a month of tuning and chasing my own ***, I noticed the stock O2's were not switching right, sitting at idle above 17:1 AFR.
So i done a search on the forum, put in Bosch 13111's as they seemed to be highly recommended. After 1 week and 1 day it is occilating around stoch'ish, swinging from 12:1 AFR to 17+ AFR, staying mainly lean. took it for a 20mile drive to warm everything up, still does the same after parking up.
Are these O2's going bad too? Monday night (two days ago) I took the battery off to attached some stereo equipment, I'm leaning towards the idea that the car is relearning the fuel trims, but why would it look the same after 20miles?
I read somewhere that oil can damage these sensors, now there dosn't seem to be any blue smoke when giving it some. Cant see any oil missing from the sump. The catch can has caught about 50ml of oil in 2 months (about 1700miles, quit a few WOT runs in that).
I'm going to log the o2 switching, as I say prehaps its relearning, or perhaps they are going duff already after 100miles.
Old 10-31-2007, 08:37 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I run 13111's and no issues, no lights.
Old 10-31-2007, 09:32 AM
14 Second Truck Club
mzoomora's Avatar
My 13111's work fine. But for the people who dont like Bosch, why not buy another brand of the same application sensor? Like a Denso, Delco, etc. They are just C5 rear o2's.
Old 10-31-2007, 09:40 AM
Well Im not saying they are crap, Im just saying that they dont seem to like even a small amount of water on them.
Old 10-31-2007, 09:44 AM
SS101's Avatar
bosch sensors are good when they work...i seem to hear a lot - A LOT - of instances where people get lazy ones from the factory
odd i know, but when they work they switch WAY faster than stock...they DO seem to be a lot more finicky and sensitive to oil and water though
Old 10-31-2007, 10:12 AM
RedWS6 00's Avatar
I've heard a lot of positive things about the 13111's, now I've got them I seem to read bad things.
When I first put them in a 8 days ago they were swinging well, and very tight around 14.6ish, like 14 to 15.4AFR, now they seem to be swinging 12 to 17+ AFR and idling mainly 17+ (cant tell exact number as off WB guage).
I need to do a log and see if they are switching slower than last week. I done a log of first start up when they were installed. I have no cats, and its damp weather here at the moment, so beyond the O2's you could see from one end of the exhaust pipe to the other is the pipes were straight. I read somewhere they a bit of back pressure is needed to read accurately, if thats that case perhaps I need to put the cats back on. How about wraping the exhaust in silver foil will that help retain the heat around the o2's, thats if its a heat issue.
Old 10-31-2007, 10:24 AM
I notice a rough idle sometimes too in my car. And it has done that before, so I switched them under warranty, and for a while my car acted brand new, then it just kinda slopes back down again over time. But since all my mounts are poly, I figure thats some of the sake I feel.
Old 10-31-2007, 11:44 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
I have had the Bosch 13111s in my car for about 3 days and ~150 miles now and the car is working fine. I am keeping a close eye on fuel consumption, but already they seems to be an improvement over the factory units with 117K miles on them.
