A.I.R.. block-off plates
Old 05-11-2003, 01:56 AM
QuickSilver98's Avatar
Default A.I.R.. block-off plates
I was wondering if anyone has tried the A.I.R block-off plates if so did you like or dislike them or run into any trouble with them thanks for the help.
Old 05-11-2003, 03:45 AM
Jabroni's Avatar
Default Re: A.I.R.. block-off plates
They are on my car now. They fit and look good and have a good deal of thickness to them. They are not flimsy at all and no leaks.
Old 05-11-2003, 10:15 AM
PongoX11's Avatar
I have AIR and EGR blockoff plates, bought new gaskets to go in between--works great
Old 05-11-2003, 10:35 AM
ApacheDrill's Avatar
Same here.. No problems on either. I used RTV to make sure i would not have any leaks.
Old 05-11-2003, 12:20 PM
toxic99's Avatar
Hey, did ya'll notice a fuel economy drop afterwards or anything? Thanx
Old 05-11-2003, 02:58 PM
Now did you guys use the block-off plates as a gasket or did you put a gasket on both sides of the block-off plate.
Old 05-11-2003, 03:52 PM
Jabroni's Avatar
One gasket in between the plate and the AIR fitting on the header. Same with the EGR block off plate.
