Which MAF is better Z06 85mm or SLP 85mm???
Re: Which MAF is better Z06 85mm or SLP 85mm???
unless you are using ls1 edit definitely dont use the zo6 one because you cannot calibrate it in the computer.. and for a 98 car the computer can only read to 11250hz anyway so either one will only be capable of flowing as much as the stock meter..
i have had both and use ls1 edit and currently use my stock meter.
sscam28-LS1Speed sells both the z06 and SLP for $149 for ls1s so I dont think this is the case.
Mightymouse-Thanks its a 2000 SS.
So if they are both calibrated for an LS1 I should still go with the SLP?
