LTs and TDs and care is still slow
LTs and TDs and car is still slow
I have longtubes and 3 inch true duals and high flow cats, now my car just sounds spectacular, but no faster than with the stock manifolds and magnaflow cat back. 13.17 before and 13.18 after . any tips?
Originally Posted by tylerdj
Does it feel like something's not right? You could have a problem with a spark plug or O2.
Would a tune make much difference on my car?
Originally Posted by blueeyeddevil141
1, there is more to driving an A4 than just flooring it....and 2 yes a tune would make a big difference.
2.) I'll have to get a tune then, thanks for the replies
Get a higher stall torque converter- best mod for an A4.
Get a tune- some cars run rich after installing LT's, and the LS1 tune from the factory is very conservative- leaving power on the table.
Higher temps and humidity of summer should make your car slower (assuming your baseline times were in cooler conditions)...if you are running the same times as you ran in better air, you have picked up some power.
with my cat back set up I went 13.1 at 107.8 then went to my true dual set up and went 12.84 at 111.8 and then tuned it and it went 12.76 at 111.2 I ran 5 psi lower on the the tuned run and didnt air up the front either. thats why the MPH was slightly lower.
