Y Pipe: Merged vs. Slammed
We all know that a slammed Y pipe (where the individual pipes are welded into each other) makes much more rasp than a merged Y (where the individual pipes go in whole to a collector). Is there any data that indicates a power difference between the two?
Originally Posted by INMY01TA
A friend of mine has QTP lts and a QTP y pipe (which has a collector) and it's raspy.
And I have a tsp "slam" y-pipe with zero rasp. Must be another one of those internet myths.
Senior Member
Ive heard true duals with rasp, Ive heard the "badass" QTP Y with rasp, etc..
Senior Member
Originally Posted by carado1984
pat g says go 4in y into 4in collector and I pipe.
What good is a 4" Y if the colector is only 3". You can only flow as much air as your smallest pipe. Id like to see the clearence of a 4" Y too
Originally Posted by Country Boy
The 4" Y is compete overkill and you will only need a 4" catback if you are over 550 rwhp.
Originally Posted by SpaZMaN
Rasp is also a matter of opnion
The way to mask the sound is to dump the exhaust because when pointed at the ground it kinda gets cancelled out.
Well, my question really wasn't about rasp ... (I guess I took it for granted that a slammed Y was more raspy) - it was about any power difference between a true merged Y (Flowmaster merge) vs. one where the the pipes are simply welded together - due to better flow, less turbulence, etc.
