Oil leak coming from in between the oil filter and motor
Old 08-04-2007, 02:50 PM
Retired Street Racer
Matt D's Avatar
Default Oil leak coming from in between the oil filter and motor
Ok guys, here's my problem. My car had been blowing oil onto my pan, and immediately I thought it was the rear main seal. But after a few oil changes and monitoring it more closely, I noticed that it is coming from where the oil filter meets the motor. I know there is some sort of gasket there, but does anyone know what exactly it is or called? Part number? I tried NAPA and Murray's and they didn't have anything like a oil filter gasket or something close to that. It is not a lot of oil, but I need to get it fixed for piece of mind. Let me know your thoughts, thanks!
Matt
Old 08-04-2007, 03:25 PM
Krab's Avatar
Are you talking about the gasket for the oil diverter plate (bolted on the pan right above the oil filter by two 10mm bolts)? Other than that, just the rubber filter that comes on the oil filter. I hate to ask, but did you take off the old oil filter gasket, sometimes they stick on the mating surface?
Old 08-04-2007, 03:28 PM
3.4camaro's Avatar
maybe oil pan gasket.
Old 08-04-2007, 03:52 PM
xBROKEx's Avatar
make sure you dont have one of the old gaskets from the oil filter stuck to the pan
Old 08-04-2007, 04:16 PM
Matt D's Avatar
No, it's not the gasket from the oil filter itself stuck on there. It is the thing that is bolted with the two 10mm bolts, that Krab mentioned.
Old 08-04-2007, 04:39 PM
Asmodeus's Avatar
Well, if you ever wanted to do an oil cooler.. W2W sells a kit that bolts up to where the diverter plate is.
http://www.w2wpowertrain.com/p-53-oi...k-for-ls1.aspx
If not, they could probably hook you up with a new gasket for it since they probably supply one for their kit to seal.
Old 08-04-2007, 10:01 PM
Matt D's Avatar
I don't want to go that route. There has to be a part number for the gasket thingy.
Old 08-04-2007, 10:06 PM
05 GSXR 1XXX's Avatar
man i have that same prob! i hate parking places knowing that when i leave people will see 4 drops of oil...(pos) lol
i thought my threads might have got stripped and i might need to buy a new pan, but maybe there is a gasket that will fix this.
PM me if you ever find out
Old 08-04-2007, 10:11 PM
Matt D's Avatar
Well, mine doesn't leak THAT bad. There is no drops dripping down onto the ground. It is only blowing all over the pan. I guess I'll try the dealership on Monday. No parts stores seem to know what the hell it's called.
Old 08-04-2007, 11:06 PM
Grimes's Avatar
If you can't find a gasket, I would just try some rtv silicone
