bump stop mod disaster
Old 08-05-2007, 04:16 PM
01BlackCamaroSS's Avatar
Default bump stop mod disaster
I am in the process of installing my heads on my car and decided now would be a good time to go ahead and port polish and grind the bump stop down on my throttle body, well i f**kd up and apparently grinded down to far, i checked with an ohm meter and its only at 4.53 ohms but when u look at the blade it looks like its way past 90 degrees
Old 08-05-2007, 04:29 PM
INMY01TA's Avatar
Guess you'll know when you start it and go wot. Should just trigger an ses light.
Old 08-05-2007, 06:27 PM
FireSilverLullaby's Avatar
Yeah if you did its wouldnt be hard to fix. just drill a screw through the stop or use put some jb weld on their.
Old 08-05-2007, 06:28 PM
Yeah if you did its wouldnt be hard to fix. just drill a screw through the stop or use put some jb weld on their. post some pics up
Old 08-11-2007, 12:20 AM
ok thanks i didnt think abuot that
Old 08-11-2007, 12:27 AM
Tainted's Avatar
bondo and duct tape baby
Old 08-11-2007, 06:54 AM
kyemt's Avatar
Default set screw
almost all the aftermarkets have a set screw and nut on there
Old 08-11-2007, 07:34 PM
5_02ls1's Avatar
i thought i went to far 4.65 but it has never set a light yet....id say you are fine....
Old 08-12-2007, 09:46 AM
2002ws-6's Avatar
I ground mine till 4.7 volts on the meter, but the throttle cable won't pull it that far open, pedal hits the little stop thing inside the car.
