CKP, Low Oil Level, Starter Wiring with Headers. Solutions for routing??
Old 08-06-2007, 10:00 PM
helicoil's Avatar
Default CKP, Low Oil Level, Starter Wiring with Headers. Solutions for routing??
Has anyone came up with a good method to protect and route the crank sensor, low oil level, and starter wires around a 1 7/8 Kooks hedder. It seems that if these were longer they could be routed more nicely to aviod the hedder heat, if it is even a problem.
Just put mine together and don' t like how close this harness is to the hedder tubes. Looked on Casper's site and didn't see any extensions for this harness. Anyone come up with a good solution or am I worrying abuot something that is not going to be problem. It is heat taped from the factory.....but damn its close!
Old 08-06-2007, 10:11 PM
bsf
bsf's Avatar
I wrapped a bunch of wires with thermal reflective wire harness wrap. Luckily, a friend had some I could borrow so I could finish it up. I ordered wrap to replace what I used from Thunder Racing. They had the best price I could find.
138-010413 DEI Cool Tape, 2"x60' $52.99
138-010416 DEI Cool Tape, 1-3/8"x30' $26.99
Old 08-06-2007, 10:34 PM
Ferocity02's Avatar
I wrapped mine with aluminum foil and duct taped them as far away as possible.
