Best box muffler to replace my Flowmaster 80...
Sup, lookin' at eventually upgrading my outdated Flowmaster 80 (1 in, 2 out) just b/c i've had it for so long and am looking for a different sound. My goals are as follows, any help would be appreciated (sound clips are welcome too, i've already destroyed LS1Sounds):
- LOUD
- mean (i like the sound of Borla, but expensive)
- 2 outs (want 2 functional tips)
- want to spend under $200 (that's MAX)
- need clearance (this shouldn't be an issue but i want to be able to simply swap my muffler now w/ another one, same spot behind the axle)
- good flow
Thanks.
- LOUD
- good flow
Thanks.
I have Hooker LT & ORY with the Flowmaster Catback too. I have a cut out before the axle. I too have wanted to replace my muffler but it sounds good now. The Hooker is ok and Magnaflow is too quiet at idle. So I'm keeping my POS one for now. The Flowmaster flows for **** but it does sound good. Since we have cut outs what difference does it make? Don't you think?
I guess, it's just that open engine REALLY does get to you after a while (not to mention i have dual cutouts before the Y-merge so it's DIRECTLY underneath me when they are open). Just looking for a good flowing, LOUD exhaust when i have it capped up.
Originally Posted by MM98
Spintech... But get their race version, not the street stuff.
-Mike
-Mike
and as far as the actual products go, which would you recommend of these 3?
http://www.spintechmufflers.com/spin...tno&Otype=race
I also wanna make sure i can do 1 in 2 out if possible.
Originally Posted by xBROKEx
you may wanna raise your budget a bit
^^Sorry man, I forgot u wanted dual outlets... You're gonna have to use one of their street split case mufflers... They're not bad, just won't flow as well or be as loud as the race style.
Mike
Mike
Originally Posted by Vrbas
F'in A. Well i could always go w/ 1 non functional tip right? Lame. Anyways, still out of those 3 which would you recommend?
http://spintechmufflers.com/spintech...ry=4&diagram=4
Neither, those are all single in/out style mufflers... Here's the part# you need if u decide to go with a Spintech.
No no no, i'll cross that bridge when i get here. Out of the 3 i've shown you (let's just pretend i don't have to have 1 in 2 out), which would be the best?
http://spintechmufflers.com/spintech...ry=7&diagram=7
Sounded great, but was a lil loud for my taste... This is what I would recommend for a 3" set-up.
Quick question: can you split a pipe so that it will flow through 2 tips after it leaves the 1 out? Thanks for all the help man.
