When should the coil packs be changed?
Old 08-08-2007, 07:09 PM
SSNISTR's Avatar
Default When should the coil packs be changed?
Just as it says. I have 60K on the factory packs. What are the signs that I should toss some new ones on?
Old 08-08-2007, 07:53 PM
FatZ28's Avatar
Ive never heard of anyone having to replace them to tell you the truth.
Old 08-08-2007, 08:06 PM
ssgunny's Avatar
I am not near mine but I guess the easy answer is the owners manual would say when they would need to be changed out?
Old 08-08-2007, 08:08 PM
ckJoshZ28's Avatar
After a little research it seems as though the coils are either good or bad, no need to replace. However, the second I have $600 laying around I will jump on them on the basis of an appearence modification to complement the wires...
As for MSD's claims of increased spark output and decreased time it takes to deliever, I doubt you would see any type of difference on a stock motor. It would take some crazy kind of cylinder pressure to need a spark like that.
planemech2's Avatar
When a coil fails, then change it.
Old 08-09-2007, 01:51 AM
ShortChevy's Avatar
Right there is no need to change a coil unless it is failing or misfiring
Old 08-09-2007, 10:28 AM
WS6NIGHTMARE's Avatar
Right! Mine have 196k on them with no issues. Not to mention the stock coils are used all the way into single digit time slips with no porblems.
Old 08-09-2007, 11:15 AM
blueeyeddevil141's Avatar
I just needed to replace mine after I began missing on 2 cylinders, hopefully that fixes it.....120k
