valley cover question
The LS6 valley cover is just suppose to help with some of the oil consumption problems that people see when they mod their Ls1 or have higher milage. Good to have but not necessary. You can always use a catch can or breather or even both if you see the problem with your engine.
valley cover
Originally Posted by RevGTO
I wouldn't. You'll have to grind a tab off your block to make it work. That's something I'd rather not do unless absolutely necessary. Plus I don't think the benefits are all that dramatic. I'd run a catch can if I found an oily intake during the install.
