How do you mount hangers on TSP duals..?
Old 08-12-2007, 03:26 PM
carado1984's Avatar
Default How do you mount hangers on TSP duals..?
do you drill through the floor board and take the carpet out of the back seat and bolt it.. ? Is it a pita? Does it leak?
Also... Are the mufflers connected with clamps or are they attached to any part of the pipe..?? How long are they??
I think im going to swap them out for 2 hooker aerochamber single in single out 3" so i need to know length.
Old 08-12-2007, 04:01 PM
Reject's Avatar
what i did on my friends car was just welded them in to the floorboard. we didnt even take the carpet out, which i would say you do since it started to smoke for us! lol
Old 08-12-2007, 04:46 PM
Da Swami's Avatar
I used a 3/8" bolt, a split lock, a fender washer and a nut to mount mine.
The only PITA is cutting the stupid thick carpet.
Mark where you want it, drill a tiny hole through from under the car, then poke a nail through and have someone hold it so you can go up and see where exactly the carpet needs to be cut.
Old 08-12-2007, 04:53 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had the Dynomax Race Bullets on mine and they were 18" long
Old 08-13-2007, 02:35 PM
carado1984's Avatar
thanks.. im going to get the sweet thunders and put weld 4"in extensions onto the hooker aerochambers to make them fit.. Ill post a video since no one has done them in a true dual one in one out combo yet.. i figure it should sound somewhat like the hooker cat back but louder and a better!
Old 08-13-2007, 07:42 PM
Bonertee's Avatar
I didn't have to cut my carpet. I just reached under it. When you take the bottom part of the seat out, there is a hole where the seat bracket mounts. Drill carefully and don't go through the carpet. Get an extra set of hands to help hold the bolt once you put it through the floor.
Old 08-13-2007, 08:13 PM
KingOfCold's Avatar
I just welded mine to the seat pans while a buddy held the carpet from laying on the inside of the pan. Do yourself a favor and get a TTA so that you can tuck the exhaust up close to the undercarriage. Otherwise it will drag over speed bumps and look pretty shitty IMO.
Old 08-13-2007, 10:49 PM
ramairroughneck's Avatar
Whats a TTA?
