HELP swapping TB housings
Guys I bought a Ported housing and I am swapping them as we speak but I am REALLY stuck on putting the spring into the new one. I dont know how to make the thing get tension and stuff.
Can someone help me out ? If you guys have pictures then better!
Ok guys, I just installed the spring BUT now I noticed this housing doesnt have the hookups for the coolant hoses???
What can I do now ???? Can I take the ones from my old TB into this one ? Or am I stuck with doing a TB bypass ???
Its a bitch and yes. They are pressed in and so you will have to work em out and press em into the other housing. Before you put em in put the tubes in the freezer overnight and leave the TB outside in the sun for a few ours and it will go back together alot easier.
Ok so, I need to get them out however I can, then leave the tubes in the freezer overnight and then put them on the new housing and then leave them in the sun so they can expand right ???
Originally Posted by socmguy
yes. good luck getting your old ones out. Why don't you just buy a hose adapter and do the bypass, it takes 2 minutes.
Right now I have a TB bypass since I did the swap a couple hours before I went to work and I didnt noticed that the new TB housing didnt have the tubes
