Single in/single out???
Old 08-16-2007, 01:47 AM
Smoke346's Avatar
Default Single in/single out???
Anybody out there ever try and/or run a 3" single in/single out flow instead of a crossover muffler????
'02 SS w/ LT's, hooker Y-pipe, 3" main pipe to crossover flow, no cats
I don't like the "popping" sound the exhaust puts out in the 2300-2600 rpm range. Seems like I hear a lot of F-bodies that do this. I have a '00 sierra with a single in/single out and it sounds fine, but its prety much stock, the SS had a cam/head/tune setup so I really would not like to lose power. Thanks.
Old 08-16-2007, 02:04 AM
bww3588's Avatar
Mufflex makes a 4 inch catback that uses a single in single out deal......
Old 08-16-2007, 04:21 AM
playtoy's Avatar
You can tuck it up just right where you cant see anything. I did a Flowmaster Super 40 on my Ta. My buddy did the same on his SS.
Old 08-16-2007, 09:25 AM
MM98's Avatar
I'm running a 4" 30 series race muffler from flowmaster, love it!!!
Old 08-16-2007, 10:05 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Sounds strangely enough like the one on my Z28.
Old 08-16-2007, 12:15 PM
Smoke346's Avatar
Would you recommend going to a 4" pipe and muffler or keep my current setup of a 3" pipe and add a single in/single out 3" flow?
Old 08-16-2007, 12:32 PM
KONG's Avatar
3", and try a magnaflow or a dynomax ultraflow muffler. Deep sound without all that raspy ****.
Old 08-16-2007, 12:57 PM
LS1W66's Avatar
I have a Flowmaster single on the left set up on my car. It is actually a kit available for `96-97 camaro's but it works on LS cars. It uses a 2 chamber 40 series muffler. Mufflex also sells a 3.5" kit if you don't want the 4" one.
Old 08-16-2007, 03:38 PM
gollum's Avatar
Here's GM's 1998 SS/WS6 single outlet exhaust. I have it bolted to my 2002 SS.
Old 08-16-2007, 04:48 PM
Strahley's Avatar
Have you considered true duals, either dumped at the axle or out the back? That would get rid of your problems
Old 08-17-2007, 05:47 AM
Smoke346's Avatar
I have considered true duals, just haven't done enough research to see how it's done, if I went that route I would go all the way out back with it. But under the circumstances, I'll probably stay with the 3" and get a good si/so muffler.
Old 08-17-2007, 11:43 AM
Shadow1999's Avatar
I have a custom single in/single out using 3" Borla offset XR-1. I had the shop tuck it as high as possible so you can't see it. Sounds good to me (refined and deeper).
Old 08-17-2007, 11:45 AM
LS69TA's Avatar
I've ran a single in/out Flowmaster 40-series 2chamber before on my '98 T/A. Sounded ok but I still had cats on it. Wasn't quite loud enough for me.
Old 08-17-2007, 06:32 PM
shaun's Avatar
my exhaust is set up like that.
i have a slp lm 2 muffler and it sounds realy good.but i have stock manis and cats so i dont know how it will sound with lt's.
im more than positive that it out flows a cross flow.
Old 09-15-2007, 10:19 PM
SuperSweet's Avatar
sound clips please???
