LS6 Intake Install - Any benefits to leaving the stock coolant lines?
I know some guys are removing them and blocking the rear 2..
I know some guys are leaving the stock lines in place..
Is there any benefit to removing them?
Is it better for the car to leave them?
I have heard leaving them helps keep the #7 cylinder cool??
Just curious..
Thanks
Jeff
Just curious..
Thanks
Jeff
I left mine in. My car didnt have a cooling problem before so I didnt feel like fixing something that wasnt broken. It just took about two hours to grind down the tabs on the bottom of the intake w/ a dremel.
Originally Posted by theblur98ss
I didn't think they would fit with an LS6???
I hear it's not brain surgery, and since I am a noted brain surgeon, I should be ok..
I swapped mine out with the ls6 coolant pipe and rear plugs and haven't seemed to have a problem. But I don't have really hot weather, don't run at the track much, and have the 160 degree t-stat in with tuned fans
I just used two of the ls6 coolant pipes, no cutting or worrying whether or not it will cool properly. The write up on LS1HowTo.com is a good guide, I followed it to the dot and havent had any problems.
Pontiacerator
Here's a thread with the pics: https://ls1tech.com/forums/generation-iii-external-engine/697788-grinding-ribs-ls6-intake-pics.html
I used what looked like a giant pair of nail clippers (really I think they were tile clippers or something) and just clipped off all of the ribs that were in the way. Then I just Dremel'd down what was left to smooth it out. Worked like a charm, was free, and easy.
