want to know what all needed
Old 08-22-2007, 10:57 AM
fuseone's Avatar
Default want to know what all needed
ok i got the AIR DELETED so i can remove it. so what all do i need to remove it now i know you need the two block off plates is any thing else needed? i would use the search but its not working out for me right now.
Old 08-22-2007, 12:25 PM
RoDan's Avatar
Just the block off plates. Remove the pump from under the driver's side headlight. Then follow the big black hose up to the next things that must be removed. There is some sort of distribution block for the air that sits on the driver's side of the motor way in the back then each AIR hose comes off of that to the headers/manifolds. Remove all that, and then use the block off plates and you should be set.
I too am removing the AIR system in one of my cars, but I do not have a set of block off plates--where is a good place to get them?
Old 08-22-2007, 12:40 PM
tylerdj's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/673299-air-removal-pics.html
Old 08-24-2007, 12:45 AM
fuseone's Avatar
yea but this is on a 01 so does that make a difference since it dont have the egr?
Old 08-24-2007, 12:49 AM
fuseone's Avatar
like is there any thing behind the intake i have to plug up?
Old 08-24-2007, 01:47 AM
RoDan's Avatar
no, there is nothing to plug up. Remove the hoses and such, and use the 2 block off plates and you are set.
Old 08-24-2007, 08:59 AM
tylerdj's Avatar
I had to plug a vacuum line that went behind the intake.
Old 08-24-2007, 09:25 AM
Ceissus's Avatar
There's no vacuum line associated with the AIR pump....is there?
Old 08-24-2007, 10:04 AM
fuseone's Avatar
i keep hearing mixed things some say there is some say there is no vaccum line which is it?
Old 08-24-2007, 10:06 AM
svodave's Avatar
Me too. It's a very small line behind intake. Plastic I believe with a rubber end on it.
Old 08-24-2007, 10:08 AM
tylerdj's Avatar
There was on mine. When I removed the little air solenoid from the top/driver area of the intake there's on vacuum line that was left and needed plugged. I'll see if I can find a picture of it anywhere.
It was the same one that svodave is describing.
Old 08-24-2007, 12:12 PM
fuseone's Avatar
tyler what year was the car you removed it off of?
Old 08-24-2007, 01:00 PM
99blancoSS's Avatar
There is a difference in systems in the years of the cars. 98-99 had one type I think and 00-02 had another.
EGR and the air system are two different animals on my 99
Old 08-24-2007, 01:15 PM
tylerdj's Avatar
A 2000. I believe 00-02 should all have the vacuum line that has to be plugged. I'm not sure about the 99's.
Old 08-24-2007, 01:51 PM
Ceissus's Avatar
ah ok, that's it.
mine is a '99
