best intake manifold
Old 08-23-2007, 11:45 PM
mrclean200518's Avatar
Default best intake manifold
i have a 98 trans am m6 with pacesetters 3 inch tsp catted y pipe and msd coils with slp cold air kit. i want to put a head and cam package on it later on but right now i want a intake so what is the best intake out there i been looking at a ls6 intake but is the fast intake or wiend any better . im lookin for low end power from 0 to 100
Old 08-23-2007, 11:49 PM
tylerdj's Avatar
For your setup the ls6 should flow plenty for you but if you want to spend the extra money you could go with the FAST.
Old 08-24-2007, 06:43 AM
radkon's Avatar
Fast 90 > Fast 78 > LS6 > LS2 > LS1 > truck manifold
Best bang for the buck is the LS6 for about $325 used around here.
Old 08-24-2007, 10:24 AM
with the fast can i keep my egr stuff. also it wont hurt my performance , i hear sometimes bigger isent better
Old 08-24-2007, 11:14 AM
68birdls1's Avatar
They make ls6 intakes that you can hook up your egr crap up to now I believe. But ls6 is def the best bang for the buck.
Old 08-24-2007, 11:33 AM
93redBIRDman's Avatar
With the FAST intake, you CANNOT keep EGR. With the ls6 manifold you can ONLY if you have the one sold by SLP with the EGR mod done. They are $550 new, but I just got one on here for $350 shipped. got lucky
Old 08-24-2007, 11:44 AM
dlove's Avatar
go with the ls6
Old 08-24-2007, 02:08 PM
5.3LJimmy's Avatar
Really? This is an excerpt from the fast instructions:
4)For EGR use (1998-2002 Camaro/Firebird) you must open the hole in your new manifold. Use a large diameter drill and Dremel type tool to modify polymer (30mm hole). Be careful not to damage the upper diameter where the o-ring seals (fig.12).
And this is the link in case you want to read the whole thing yourself:
http://www.fuelairspark.com/Instructions/147.asp
Old 08-24-2007, 02:22 PM
SpecialK's Avatar
You have to modify the Fast Intake to use your EGR.
You should base your Intake selection on your heads and cam selection. If your going with a "baby cam" a LS-6 Intake will serve you well and flow plenty. But if your going to drop 2.5K on a set of awesome heads along with the cam then a FAST 90 makes sense because your intake will be your bottleneck. Albeit a small one. I was going to use a ported LS-6 intake until the shop dropped it and cracked it. Then I got my FAST90 and went with a larger cam than originally planned. Though I do kinda regret the larger cam, can't just roll into it and go I have to downshift.
Old 08-25-2007, 12:43 PM
thanks for all the input guys i want to keep a like stock with all my egr hookups and stuff i do plan on going with a set of cnc ls6 heads from gmpp and a cam
Old 08-25-2007, 01:35 PM
JPH
JPH's Avatar
FAST all the way.
Old 08-25-2007, 05:22 PM
Danny2tek's Avatar
LS6 gets my vote
Old 08-26-2007, 01:06 AM
Havok2's Avatar
ls6 for your mods
once you put cam/heads go to a 78/90 fast
Old 09-01-2007, 04:57 PM
thanks alot guys i went with a zo6 02-04 ls6 cam and a set of the z06 ls6 heads. i think ill go with a fast intake
Old 09-01-2007, 05:06 PM
jareed02's Avatar
go with the ls6..when you do more mods go with 90/90
