STOP GRINDING for Long Tubes
Old 08-24-2007, 01:06 AM
lt1camaro95's Avatar
Default STOP GRINDING for Long Tubes
I was reading the stickys about grinding the K member and the oil filter housing to get a long tube into the driver side. This is very unnecessary. That part of the oil filter that everyone is grinding....unbolt it. It take about a minute to get off and no gringing needed anywhere. Just be ready with new bolts, I snapped one off with the air tool. By the way, I have no exhaust on yet, just long tubes, my ears are ringing.
Old 08-24-2007, 01:13 AM
Krab's Avatar
That part is called the oil diverter plate (held on by two 10mm bolts) and sometimes you still have to grind down the K-member to keep one of the primaries from hitting. It all depends on what type of longtubes you get. Some require you to grind down the K-member, others don't.
Old 08-24-2007, 01:34 AM
LS1Silverado05's Avatar
All I know is that pacesetter LTs on a 99 WS6 A4 car slide right in. No grinding, no mount moving, no steering shaft unbolting, nothing. I am sold on pacesetter after that install. Fantastic fitment!
Old 08-24-2007, 09:01 AM
tylerdj's Avatar
I've never had to grind anything to get LT's in. I've installed Pacesetter, Hooker, Jet Hot, and XS.
Old 08-24-2007, 09:23 AM
Camario's Avatar
kooks race headers here no grinding
Old 08-24-2007, 09:33 AM
svodave's Avatar
Same with the XS headers! I just handed them up to my brother from the bottom of the car and he started the bolts in.
Old 08-24-2007, 09:42 AM
blueeyeddevil141's Avatar
Yea, My headers went in the drivers side in less than 15 minutes from me putting them in and bolting.
Old 08-24-2007, 11:00 AM
I got the jet hots and seen everyone on stickys saying gring away. Two 10mm bolts was way easier than gringing. What is the oil diverter for? Is that if the filter is too blocked to bypass the oil?
Old 08-24-2007, 11:05 AM
3rdgentug's Avatar
good to know, i got pacesetter lt and was wonderin if id have to grind
yay for no extra headaches for once!
Old 08-24-2007, 11:25 AM
m6speed's Avatar
driver side fits fine on mine, pass side hit the k member, grinded it down a long time ago. i have qtp's
Old 08-24-2007, 11:28 AM
Trunion King
bene's Avatar
I didn't grind anything for my Stainless Works LT headers.
Old 08-24-2007, 12:05 PM
SS_Hokie's Avatar
Headaches you will still have..........maybe not from the headers, but you will have headaches, backaches, arm-aches, hand-anches, etc.....
Old 08-24-2007, 03:03 PM
True. My hands still hurt from torquing down the bolts with a wrench. Abs hurt from laying across the motor.
Old 08-24-2007, 04:33 PM
Da Swami's Avatar
I ground the casting tab for my Pacesetter's.
Old 08-24-2007, 11:24 PM
98Camarod's Avatar
I didn't grind anything, I just beat in the part that was hitting on the body. They slid out and slid right back in for my swap.
Old 08-24-2007, 11:33 PM
5_02ls1's Avatar
must be some of those 1000 dollar headers my 300 dollar pacesetters slid right in
Old 08-25-2007, 12:11 AM
bsf
bsf's Avatar
I had to either remove material off the RH K-member or "massage" a primary of my QTP's. I chose to remove a thin slice of K-member w/ my reciprocating saw w/ the exhaust installed. No big deal.
