2 Rear Intake Sensors???
Old 08-27-2007, 08:12 PM
Halloran's Avatar
Default Seriously WHERE IS THIS??!!
I was just curious if anyone know what sensor this is or where it plugs in? The sensor for the back of the intake manifold is different than this one and is on the passenger side of the car. I can't seem to figure it out.
Old 08-27-2007, 08:38 PM
ls2 bait's Avatar
look over to the drivers side of that plug and the other half of it will be dangling behind the head. feel around and u will be able to pull it back up. i went thru the same thing yesterday
Old 08-27-2007, 09:03 PM
Halloran's Avatar
The other end to this plug is behind the driver head somewhere? Is it on the same harness? I don't feel any loose wires behind the drivers side...only the wires that ground to the head.
Old 08-27-2007, 09:40 PM
bczee's Avatar
I see that you haev the oil sensor and cam sensor. .that would only leave the MAP, which is attached to the back of the manifold or the Knock sensors which has a plug on a short harness that matches another plug on the main harness.
Old 08-27-2007, 09:54 PM
ls2 bait's Avatar
map sensor plug is on the other side of the harness. forget that one its not it. its in the same harness. its behind that head somewhere. if u cant feel it climb under the car and a plug will be hanging down.
Old 08-31-2007, 08:50 PM
Halloran's Avatar
I've gone under the car and felt the entire harness with my hand and there is no place where this plugs in on the harness. I don't know if maybe someone has a schematic or diagram about where this sensor goes on the drivers side of the car but I can't figure it out for the life of me!
Please Help!
Thanks
Old 08-31-2007, 10:46 PM
Black Sunshine/ 00SS's Avatar
Looks like it is on the drivers side to me. If that is the case, it would be smog related. Have you had all that removed? I'll take a look at mine tomorrow.
Old 08-31-2007, 11:12 PM
Halloran's Avatar
The car is stock from when I bought it. I haven't removed anything either. The sensor is on the behind the driver's side head. If it connects to something I can't figure out what it is. Please let me know what you find out on your car.
thanks so much!
Old 08-31-2007, 11:32 PM
ls2 bait's Avatar
wish i was there to help u man. but i promise u that there is another plug hanging back there. its in the same harness and it has a clip on it to clip itself onto the metal bracket on the drivers rear of the manifold.
Old 09-01-2007, 12:32 AM
Halloran's Avatar
So when it's connected is it behind the head or the manifold? The only wires on the back of the heads are bolted directly to the head. I just need to know what the thing looks like when it's connected. Is it visible or hidden behind the intake somewhere?
Old 09-01-2007, 02:33 AM
Halloran's Avatar
Moooohahahaha! I took off the intake and VOILA...there it was tucked underneath the damn thing. Better not make that mistake again ;-)
Thanks for all the response!
