Identifying Heads LSX
Old 08-28-2007, 05:38 PM
NovaCain383's Avatar
Question Identifying Heads LSX
I just got another car. The guy let me have some heads that he had got for the car. Is there a website where I can look to see what heads they are or what they are off of? Or is there a list on here? Can't seem to find anything on them everywhere I have looked. Also which number do I check to see what they are. I found all the numbers but also not sure which one to go by.
Any help will be appreciated.
Thanks,
Criss
SBP
Old 08-28-2007, 06:04 PM
Order 66's Avatar
243 are LS6 heads
241 are 01-02 LS1 heads
317 are 6.0L heads
Thats not all of them but i hope it helps.
Old 08-28-2007, 06:09 PM
Tainted's Avatar
853's are the 98-00 heads and te crappier of the headers, with the 243's being the best. They only came on LS6 motors though
Old 08-28-2007, 06:13 PM
If they are 6.0L heads, would they be good to use? Not sure yet but will look at the numbers again on my lunch break.
Thanks for the help guys. I am trying to get setup to start building a little power. The car already has a D1SC, longtubes ORY and exhaust. The guy said it made 47X to the ground. But ready to up it a little.
Thanks,
Criss
SBP
Old 08-28-2007, 06:24 PM
00Z-28Maro's Avatar
I think 98's are 806 IIRC. I'm too lazy to run out and look right now tho.
Old 08-28-2007, 07:23 PM
Order 66's Avatar
6.0 heads are good to use on forced induction motor. Just like a LS6 head just a little larger which is good for boost.
Old 08-29-2007, 03:26 AM
They are the 317 6.0L heads. Just checked them. What size valves are in these heads. How much boost with these heads and stock bottom end?
Thanks,
SBP
Old 08-29-2007, 10:16 AM
EarlSS's Avatar
My car is a 00 and it has the 241 heads on it.
Old 08-29-2007, 11:56 AM
00Z-28Maro's Avatar
Some late year 00's got 241 casting heads also.
Old 08-29-2007, 11:59 AM
Numba1Stunna's Avatar
my 2000 has 241 castings too. are these better than the 853's
Old 08-29-2007, 12:01 PM
Eurospec2's Avatar
not sure about the numbers, but 97-98 heads are the same, heads from 98-00 were not the same at all
Old 08-30-2007, 09:42 AM
00Z-28Maro's Avatar
241's are supposed to be better than 853's and 806's. Something about the method of casting them that makes the finish smoother IIRC.
