cam swap help!!
cam swap help!!
ok im doing a cam install in about a week or so and i was wondering if anyone know what size is the harmonic balancer so i can use a deep pack socket to get it out.. is that the fasted/easiest way to take it off and also to put it back on thanks in advance..
yea like he said its 24mm if you cant get the tool to lock the engine in place you could remove the starter and use a good sized and strong flat tip screw driver or prybar to hold the flywheel still.
