slp air lid fitmet
Old 09-05-2007, 07:23 PM
wags98's Avatar
Default slp air lid fitmet
I was just wondering if its normal for an slp air lid not to fit exactly as tight as a stocker lid...actualy it does seem to fit neerly as good as the stock one...I know its the right one its for the year of my car..just wondering if there all that way..
Old 09-05-2007, 07:26 PM
nexvctm2001ss's Avatar
Did u put a bellow on the car??? if so thats the prob.
Old 09-05-2007, 07:51 PM
wags98's Avatar
no bellow
Old 09-05-2007, 07:54 PM
Where is it not fitting??? or what is it doing???
Old 09-05-2007, 08:09 PM
wags98's Avatar
its mainly in the back of it.. the 4 progs go into place that hold the back down but its not a tight fit right along the back front and sides fit good its just the back...I felt around there and didnt fell any air movement so maybe its good hell i dont know??????????
Old 09-05-2007, 08:33 PM
Should b fine as long as the tabs are in there with no stress on them and the lid is over the filter correctly(squared up with the base) other than that i don't know sorry.... maybe someone else will chime in
Old 09-05-2007, 08:54 PM
Cld069's Avatar
Hm, Im on my second lid and they both have fit pretty snug. The only bad thing is that it slightly rubs my hood.
Old 09-05-2007, 10:24 PM
JScamaro's Avatar
As long as the tabs aren't popping off and its secured to the maf good you should be fine.
Old 09-06-2007, 04:12 PM
wags98's Avatar
good enough thanks 4 the input...
Old 09-06-2007, 04:17 PM
zuuhlsT/A's Avatar
I gotta SLP Blackwing with the smooth bellows and a K&N filter with no probs. Do you have the top of the lid on right? It should not be over the front! Thats mostly what the prob is. Or do you have an 85mm MAF. That would throw it off a bit!
Old 09-06-2007, 04:25 PM
wags98's Avatar
the slp air box is flush with the bottom in the front not over lapping .and the maf is granatelli...
Old 09-06-2007, 04:34 PM
zuuhlsT/A's Avatar
You still got the stock "accordion" type bellow? You should be able to squeeze that sucker in to get the lid to fit. The lid should not be flush with the front of the bottom piece. It should be back alittle.
