Post here if you have overheating problems and/or an aftermarket Radiator!
I've searched quite a bit and there isn't much feedback on this topic. I have seen a lot of overheating threads lately and I am also having overheating problems. We had a radiator shop boil out my stock radiator and it helped but I am still heating up to 215*. That's a big improvement from the infinity it was heating up to just a week ago but still far from the 180* max temps I used to see while my radiator was still good. Search has revealed Be Cool, Griffin, Evans, Fluidyne and of course the LT1 radiator. However, there is not a lot of feedback on how these are performing. All I want is something that will fit without modification and perform better than a brand new LS1 stock radiator.
So please post here and tell us how your aftermarket radiator is performing. It would also be nice to know who you purchased it from and how it fits.
Thanks!
Thanks!
I got the Be Cool Part # 60028 and personally I liked everything about it. Minimal mods to make it fit (trimming of the radiator fan shroud (took all of 20 seconds) and bending of the radiator support (took 5 minutes with a pair of channel locks)). I bought it from Summit as they do price matching and I just did a lot of research on the web to find the cheapest price then let them know about it... Along with the radiator I installed a 160 t-stat, added some water wetter, and had my fans tuned... Also I switched to the Prestone Extended Performance Yellow/Green coolant instead of that Dexcool crap that coagulates and gunks everything up...
The reason I upgraded was because my stock LS1 radiator cracked on the side plastic areas and started spewing coolant out everywhere... couldn't have been better timing either... It happened 2 weeks before I moved to Phoenix, AZ where it gets hotter than ****... NO OVERHEATING PROBLEMS since i've been here with the new radiator... I can sit in traffic with the A/C on full and the temp never rises... When I was in San Diego and got the fans tuned we had the EFI Live hooked up to it and at idle the temp never got above 178
I know some guys say they had issues installing their Be Cool radiator, but mine went really smooth and I'm a completely satisfied customer....
Here's pics of the Be Cool vs. LS1 radiators...
Yeah I came across your posts when doing a search. I don't have A/C anymore and I have a separate cooler for my TH350 so I'm not sure if the part number for my application would be the same. Sounds like you didn't have many problems with the install. Hopefully some others will chime in.
Since you have an automatic I believe you would need Part # 62028
Go here and double check...
http://www.becool.com/#Search
but then again, since you have a seperate cooler... you might wanna call em
Customer Service: 888.515.6075
Originally Posted by PewterZ28
Actually, in my case, I would need the same one you have, part 60028. Any idea why they claim it is only good to 350 HP? I'm making close to 600 at the engine.
I'm running the BeCool. I have a 403 LS2 based motor that the stock radiator couldn't keep cool. Went in pretty easy and keeps the motor at 179 to 180 degrees with a 160 degree stat and programming for the fans. I was told to get the BeCool because it is all aluminum and could be repaired and that the others couldn't... not sure if that is true, but I do like this one.
OK, so I went with the Be Cool #60028. I'm going to either install it tomorrow night myself or have my mechanic do it next Monday. I don't want to go WOT on my new motor until I get the temps where they should be. I almost went with the LG radiator with oil cooler but it was just too expensive and I can't even mention how much I have spent on my car this year. Too embarrasing to say. Anyway, I hope I don't regret not getting an oil cooler.
Just an update guys. I installed the Be Cool radiator on Wednesday night. Unfortunately it did not help my overheating problem at all. I have another thread going in the Interal Engine section and we are thinking the last place to check is the heads.
BTW, the radiator was a breeze to put in and I even have the Mezziere elec pump. However, I did have to go buy a 3/8" NPT Plug and a 1/2" NPT Plug and plug up two of the holes. I don't have A/C or an oil cooler so those holes had to be blocked. Also, my engine is really easy to work on because I don't have any of the accessories. So it probably would have been more difficult on a car that had all of the accessories.
