Catch can?
Catch can?
Ok call me an idiot but i just wanna double check something. I installed a catch can over the weekend and took my car out for a drive. NO oil in the can, which i don't believe because i burn unreal amounts of oil. So does it flow from the valley cover to the manifold or should it flow from the manifold to the valley cover?
well that is bad news, as you may be buring the oil thru your rings then if the catch can is on properly and has no oil.
Look inside your intake and see if you can see any oil- you may need a cotton swab. If it is bone dry then it is probably the engine.
How much oil do you use?
i just need to know which way it would flow. i checked it again and i have a little bit in there now. i burn about 1 1/2 quarts every 1k miles maybe not quite that much but close
The hose connected to the PCV goes to the top or inlet of the catch can and the hose connected to the front of the intake manifold goes to the side or outlet of the can. Hope this helps but with the amount of oil you are having to replace every 1K miles it sounds like it is something else.
i have oil in my exhaust pipes. but does anyone know which way it flows????? that is the purpose of this thread. does it go from the intake to the valley cover or the other way around?
