no heat shields a problem?
Old 09-10-2007, 10:08 AM
rjc1629's Avatar
Default no heat shields a problem?
When I put dumped exhaust on my car I removed all of the heat shields from the rear of the car, but my exhaust is just too loud so I want to go back to full exhaust. Will it hurt anything if I don't have the heat shields on there (specifically the one under the gas tank)?
Old 09-10-2007, 12:45 PM
Finite1's Avatar
The shop I get my work done has run quite a few cars this way, included their own without problems.
Me personally I had my gas tank heat shield removed a week or so after I got my gmmg on (around january of 07'). The banging was becoming a problem. No banging/problems since that was taken off (thanks God) and I drive a lot on AZ roads/heat.
Oh and I go to the dealership for all my maintenance generally and they never mentioned it or said anything negative about it. So I will assume it's OK.
just my .02.
Old 09-10-2007, 12:49 PM
rjc1629's Avatar
Thanks for the input, I won't have a muffler back there (going w/ a loudmouth style setup) so I really don't think it will get hot enough to do anything.
Old 09-10-2007, 04:39 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Heat shields really only need to be above any cat...mufflers get NOWHERE near as hot...cats can get 350* and above..
Old 09-10-2007, 04:48 PM
rjc1629's Avatar
Cool, I'm gonna go for it then, thanks.
Old 09-10-2007, 04:52 PM
NHRAMAN's Avatar
Exclamation
I imagine some mufflers get around 200*....but that is the temp. of a warming oven..no big deal.
Old 09-12-2007, 10:05 PM
SOM02WS6's Avatar
Your GMMG could have been banging because you didn't slide the pipe in far enough for the over axle pipe. I had the same problem and took it all off got a pipe spreader and slipped the pipe just a bit further and no more banging on the heat shield on the gas tank..
