Direct Hits Ignition any body use this?
Old 09-16-2007, 07:53 PM
BURN'EM's Avatar
Default Direct Hits Ignition any body use this?
T Byrne sells this and i was wondering if anyone runs this on their car? Post up and tell me how you like it. Or even if you think you would buy it.
Thanks
http://www.tbyrnemotorsports.com/ls1/ls1ignition.html
With the DirectHits Ignition upgrade you just need to remove your old plugs and wires and install the high-voltage ignition system. The high energy-density spark system produces a flame kernel and flame front that propagates more quickly and completely through the fuel charge. This increases throttle response, acceleration, fuel efficiency and reduces emissions. Long-term benefits include reduced carbon buildup in the combustion chamber and extended service periods. This Electrical Power product improves the transfer efficiency of your ignition system. Its patented technology raises the level of efficiency over 500 times. Upgrade to improve fuel economy and performance and provide cleaner combustion -- all due to increased high current discharge at the instant of ignition
Each kit includes
DirectHits current peaking capacitors - 1 for each cylinder
High energy 8mm wire set
Premium non-resistor sparkplugs ( Bosch/Accel/NGK depending on the application)
Installation tool (plastic 3/4' 12 point 1/4' drive socket to install the DirectHits properly to 12 inch/lbs of torque)
Dielectric grease for all electrical connections
Installation instructions
Quick Reply: Direct Hits Ignition any body use this?
