98 LS1 vs 99-02 LS1
Old 09-16-2007, 10:29 PM
Mike96z's Avatar
Default 98 LS1 vs 99-02 LS1
What is so bad about the 98 LS1's? And to convert to a 99-02 LS1 would I just need the newer wiring harness and PCM and thats it? I am thinkin about buying a 98 LS1 with T56 setup and putting it in my 96. Any help would be appreciated as well as why I should stay away from the 98. It has 103k. Thanks Mike
Old 09-16-2007, 11:17 PM
DSRCAM's Avatar
i never had any problems with my 98 in fact i guess i had one of the quick ones... ppl would freak when i told them all i had was a lid and cut out..
Old 09-17-2007, 12:50 AM
Mike96z's Avatar
hmmm, someone told me the oil pump caused most of them to fail prematurely. If thats the case, i could prob put all new bearings and a ported LS6 oil pump and have no worries rite?
Old 09-17-2007, 03:14 AM
Omega Doom's Avatar
in theory yes but you never know?
Old 09-17-2007, 03:15 AM
ApexVIII's Avatar
my 98 has 102k on it and runs strong
Old 09-17-2007, 08:02 AM
Mike96z's Avatar
i also heard the computer is wacked and has alot of problems, is this all false or is it true. Wanna know before I go and purchase this 98 LS1 setup. Thanks
Old 09-17-2007, 08:14 AM
ls1ws9ta's Avatar
The 98's are not wacked. The Computer is a bit more challenging to tune, but it can be done. The knock sensors pull like 4 degrees of timing so changing them to the new ones with the new harness would be best to fix that issue on all cars that were build pre the year of 1998. Also you would need a ls6 intake as the 01-02 cars came with one out of the factory. The oil is something you may want to replace. But mine has 177k with the stock stuff and its still running great.
Old 09-17-2007, 08:26 AM
Mike96z's Avatar
yea did the research and the 99 is the one with the oil pump problems. The 98 seems to be harder to tune and less flexible and im guessing like you said the knock sensors arent the best. Ill prob go to a 99 harness and pcm later but for now seems good. Think replacing the bearings and maybe the oil pump will help this engine last longer? Thanks
Old 09-17-2007, 04:30 PM
Juicedz28's Avatar
Slight problems pcm, 806 casting heads, and intake manifold. Other than that theres not much difference. I wouldn't stay away from a 98. I own one, lol Don't be scared off.
Old 09-17-2007, 04:36 PM
98_Formula's Avatar
yea there not that different, i talked to a tuner about it and he said tuning a 98 is not much different at all, he said thats way over emphasized at least from his standpoint. i heard some things can be more "fussy" like the knock sensors and such, but i havent had a problem with mine at all.
plus if i remember correctly, 98's were the only fbodys not to be equipped with the "black box" or was that a rumor?
Old 09-17-2007, 04:44 PM
Mike96z's Avatar
wat is a black box.
Old 09-17-2007, 05:03 PM
DSRCAM's Avatar
a black box keep all your data from the last five mins of impact or so i heard.. but yea my z28 is a beauty ive never had any problems with it in fact all my other buddies f bodies are dropping like fllies!!
Old 09-17-2007, 05:47 PM
Mike96z's Avatar
hmmmmm .
Old 09-17-2007, 06:57 PM
98_Formula's Avatar
Yea saves your data so the insurance company can check on it if you make a claim, could be an urban legend tho u never know...
Old 09-17-2007, 07:25 PM
Mike96z's Avatar
im sure they say its a black box but its actually inside the pcm.
Old 09-17-2007, 08:03 PM
simple's Avatar
thought that was only on Vettes?
Old 09-17-2007, 08:11 PM
Mike96z's Avatar
no its on all new cars im sure. it can show if you were speeding etc so that they cant do false insurance claims, like "i wasnt speeding"
Old 09-17-2007, 08:40 PM
simple's Avatar
i know what it does and what its for but i thought it was only on the Corvettes during the time the 4th gens were still being built. i know alot of new cars have it but i dont think 4th gens ever had them. i could very well be wrong but i think this info would have been out before...
Old 09-17-2007, 08:47 PM
Mike96z's Avatar
well i know a guy who when his son blew his ls1 camaro he went and checked the black box, said he was speeding, reving too high before it happened, basically saying he was racing, he threw a piston out the side of the car, he went back and checked for holes and the kid had nitrous without his fathers permission. For some reason that set off the black box.
Old 09-17-2007, 09:48 PM
simple's Avatar
LOL, sounds like some twisted words to me. maybe he had some datalogging software running. but a factory "black box", i'm not to sure about! i am in doubt of this idea on f-bodies!
