DIY C5 FAST 90/90 install instructions ??
Does anyone have this for a C5 that they can post or Email me.
I know there is a LS1/LS6 manifold swap on LS1 how to, but I wanted to check to see if there is something specific to the FAST 90/90 with TQ specs and pictures
My FAST90 is from Tony Mamo. His directions are to use a 1/4" drive ratchet/socket and follow the torque sequence for the intake. Go around 5-6 times until you cannot tighten bolts anymore. He estimates that to be around 12 ft/lbs on a torque wrench, in his words.
I believe FAST says two passes, 1st pass @ 44 in/lbs and 2nd pass @ 88 in/lbs.
