85mm MAF on 2000 LS1?
Would an 85mm Z06 maf fit on my 2000 LS1? I'm picking this up and wanted to couple it with a LS6 intake and P&P TB. Then go cam only.
My main question is, would the pins match upof the connector?
It wont fit like the stock maf did inside your lid so you will need some sort of coupler. You can trim down a 3x3 frenco and make that work. You will also need a 5 pin to 3 pin connector for the maf and you will defiantly need to tune for it or you will run rich.
Cool does anyone sell the connector outright?
I already have a 3" fernco on there. The adjustment for it being rich i can probably do w/ my predator. (well temperarily) I don't plan on installing the 85mm til i got a LS6 intake and have my TB p&p, as i have a Granatelli maf on it now.
Moderator
You can't adjust it properly with the old version Predator. Do not
know whether the "new & improved" will do it. There is not a whole
lot to gain vs a descreened (unported) stocker. Casper's sells the
adaptor harnesses. But I'd put the money toward a real HP/$ gain
instead.
instead.
I was gonna install the intake parts with a cam if that makes a difference. If not oh well i'll have an extra maf, just in case.
If that is true about the predator than it will really have to wait til i feel i have enough mods to warrant a tune.
