$$$ What would you buy?
Old 09-19-2007, 09:51 PM
Parrothead497's Avatar
Default $$$ What would you buy?
I've been looking to drop some money into my 98Z M6 for a little SOTP factor. I'm looking to spend around $3500. As of now, all that is done to the car is a slp dual dual catback. I'd like to stay away from a turbo, just because I don't want to dump a bunch of $$ into upgrades needed to support the turbo. Where do you all think I should start?
Thanks for your help
Old 09-19-2007, 10:33 PM
sixvi6-camaro's Avatar
the basic bolt ons.. long tubes, LS6 or Fast intake, Lid, sticky tires, susapens mods... then save up more because the rearend will probably go after that.
Old 09-20-2007, 11:44 AM
jag42420's Avatar
Headers, sticky tires, lid, suspension, tune, gears, cam
Old 09-20-2007, 12:00 PM
blackcat's Avatar
I would say find a used sts rear mount turbo. There is no other upgrades you have to buy. You will go from 300HP to 450 and you will be perfectly safe. 3500 dollars, great drivability until you want power. DONE. 1 mod. 150 HP whenever you want it.
Headers: 25HP
Catback: 10HP
Lid: 15HP
Cam: 40HP
Thats 85HP and you will probably need so many other supporting mods for that. Turbo is just 1 thing and your done. Plus you have the cool factor.
Sure there are more efficient turbos, but you need a new bottom end, a TON of supporting mods, tweaking your engine all the time depending on the weather.
Tim
Old 09-20-2007, 12:25 PM
ws6_bandit's Avatar
longtubes, ls6 intake, underdrive pulley, gears, suspension, cam.
Old 09-20-2007, 12:39 PM
Z28LS1camaroguy's Avatar
Intake, Intake manifold, Long Tubes, Gears, cam, some suspension, and to cap it off a good tune.
Old 09-20-2007, 02:53 PM
jag42420's Avatar
Originally Posted by Z28LS1camaroguy
Intake manifold
Oh yeah. Missed the 98 model. Intake is definitely needed.
Old 09-20-2007, 03:28 PM
matt3383's Avatar
Well im going to agree with what was said above. Excpet is your car a 6spd or auto? If auto a stall is the 1st thing. If not i would in no order
1. Headers and complete exhaust
2. LS6 intake
3. Gears, 373 for auto, 410 for 6spd
These 3 things will give you the best SOTP feel for the buck. Gears are prob the best IMO for seat of the pants
Old 09-20-2007, 03:37 PM
CaMaRo67RS355's Avatar
well if it were my car and i had that much cash... do all bolt ons known to man headers, no cats, good exhaust (i prefer true duals), underdrive pulleys, new plugs, wires (if its got some miles on it), in ur case get a LS6 manifold or go with a fast 90mm intake and NW 90mm tb dont waste ur money on a fast 78mm cause its hardly any different than the LS6, port & polish ur factory tb, lid, k&n filter, m.a.s. ends to get rid of the screens in it, there is more bolt ons that im forgetting im sure then id throw in a decent cam with supporting valvetrain upgrades, 4.10 gear to the rearend, replace factory shifter ive broken 4 stock hursts they just dont work for me, then some suspension like lca's panhard, trq arm, etc. oh yeah and cant forget a good dyno tune. beleive it or not you can get most or all of this stuff done within ur budget as long as you ARENT like me and only want the best of everything as in my case i wanted QTP $800 headers u could get pacesetters for half the price OR less. pm me if ya got any ?'s sorry for the rant didnt know i typed that much... one more thing make u a list of exactly what you want/need and post in the WTB section and scan the parts F/S section u can find some really good deals.
Old 09-20-2007, 03:44 PM
kerryt1's Avatar
quality headers, LS6 intake, lid, cam & springs, tune (on a dyno, not thru-the-mail), maybe gears, sticky tires if you're not scared of popping the 10 bolt.
Old 09-20-2007, 03:52 PM
NO GO on a mail order tune
Old 09-20-2007, 05:23 PM
Thanks for all the info/suggestions guys. My question now is would it be better to get the fast 90/90 or stick with ls6 intake? Do you think the fast would be a waste if I don't plan on getting cam/heads just yet? Also, I've read some good things on the Typhoon intake. Any input on this?
Old 09-20-2007, 06:23 PM
Full-Force's Avatar
I would say,
longtubes & ory $500
lid $100
cnc 243 heads with dual springs $1000-1200
cam $400
pushrods $100
intake $350
ported tb $100
gears & install $400
tune $400
Old 09-20-2007, 07:36 PM
id see how deep ur pockets are and make that call yourself ported and polished tb if you bought one used $100 bucks or u could send ur stock one of to be ported. for like $70 and a ls6 manifold ive seen some on here for sale for $250-$400 bucks cause they have upgraded to the 90/90. if you go with anything other than a ls6 manifold id go straight to the top with the 90/90 setup.
Old 09-20-2007, 07:41 PM
c0ncEpT's Avatar
Moser 9in w/ 4.11's and build from there.
