Valley cover question
Old 09-21-2007, 01:18 PM
WS.6#384's Avatar
Default Valley cover question
I was doing a search yesterday on ls6 valley cover. I am hoping this will elliminate the need for a catch can. Anyway, I came across where someone said the 04 valley cover was a direct fit into 02 ls1, and was even better than the ls6 valley cover. Please advise me or post the link to this thread. This is the last thing I want to be sure of before I install my ls6 intake.
Old 09-21-2007, 01:28 PM
WS.6#384's Avatar
Found the post here https://ls1tech.com/forums/showthrea...t=valley+cover opinions?
Old 09-21-2007, 01:41 PM
MM98's Avatar
PM'd you & it will not be a direct fit unless you have an ls6 block... You will have to grind/cut off the casting tab in the front passenger side of the engine valley in order to fit the new cover... I've been running this set-up on my new motor for about 2000mi now & my intake is bone dry with no oil consumption.
Old 09-21-2007, 04:33 PM
WS.6#384's Avatar
I ordered these today
-12577927 (valley cover, comes with bolts & gasket)
-12594779 (hose)
and I am thinking will need these also.
Valve cover plug - 12568011
Rubber grommet - 12568011
PCV Valve - 12572717
10 inches of 5/16 ID rubber fuel line
Old 09-21-2007, 04:50 PM
MM98's Avatar
The grommet & plug will be all u need.. The cover has the pcv in it & just uses the u-hose from it to the manifold.
