How I fixed my banging y-pipe for free. BIG PICS
I've done this to a couple cars now and it's worked every time. I've got $0 in this, but you may spend a couple bucks if you don't have a welder or some sort of paint at the end.
First pic is stock and you can see the minimal clearance betweeen the floor and exhaust, I had less than 3/4"
Next I took my cutoff wheel and made two cuts along the floor board where the drivers exhaust pipe runs.
Now with the floor cut, I took a hammer and hammered it down to create more clearance. I had to use a 6lb sludge for some of it. BE CAREFULL NOT TO HIT YOUR FUEL LINES WITH THE HAMMER.
Once it was hammered flatter I hit the sided in to match the center and took my welder and welded up the 2 cuts and then used Rubberized Underbody Spray Coating to seal it back up.
Here you can now see the extra clearance. I gained about 2"
Yes, my welding isn't the best, but it works.
Took me less than an hour to do and no more banging y-pipe and no extra vibrations from having to do poly mounts. My car vibes enough from the cam.
at all the negative comments and the poster getting pissed....
I give you thumbs up and props on the new ideas and guts to do it, but cutting into a car like that is something that I personally couldn't do, as I'd be scared of structural integrity. If it works, and doesn't bother you or hurt your car KUDOS!
I'm not getting pissed. I just think it's funny that some people think these cars are precious. I just have a different state of mind on these things.
I posted to help others who may want a cheaper alternative.
Wow... You would actually rather cut a structural part of the car than flatten a pipe a little bit... I'm sorry but this is one of the stupidest things I've ever seen on this site. Or any of the other car sites I am a regular on.
Sorry but its not that I think it is precious, I just take pride in the work I will be doing on my toyz! but to each his own.
wow I thought this was gonna be another rubber snubber thread wow......i didnt cut my sub frame but i did take a big ole ****** hammer to it......no banging at all now on thenew x setup.....
Thats not exactly a new idea. I have been doing the same thing for 2 years now on everybodies car I work on. The only difference is that I just cut that plate completely out right there. Its not a big deal, and its not hurting the structure of the car.
You dont gain more than 1/2" though if you have longtubes. With longtubes a straight piece of 3" pipe will be rubbing right on that spot on the body, and that piece only hangs down about 1/2". You still have the fuel lines right there also so you cant get the pipe but so high.
Nice job... I'm looking into what I'm gonna have to do... and anyways its not gonna hurt the structure just dont go pullin a boat around.. lol that would be a bitch to weld.. nice job.
"I'm not getting pissed. I just think it's funny that some people think these cars are precious."
i'm sorry....generally anything i pay $15,000 for....over the course of 5yrs....i consider pretty precious.
glad you have disposable income
