Just got my lts and ory and have some ?? on the install
just got my long tubes there pacesetter and the ory i just wanted to know what do i need?? and if im going to need to grind or cut anything??? and what the fastest way and if there any steps i need to know about it before i start the install?? and if there any thing i should change while doing the install?? and i have a 99 z28 6 speed thanks for your time and i already did a search and cant really find anything
Here's a few tips: Don't use the paper gaskests that come with the headers. If you have the ability to use a lift, do it. If not jack the car up as high as possible, while being safe about it. If the spark plugs need to be changed now is the time to do it. I dont know if you grabbed 02 extensions, if not, go to local auto store get bosch vette 02 sensors ( they are more than long enough). There might be a small square tab on the rear drivers side of the block that might impede getting the header up, you can grind that down. Oh yeah fire the car up with headers only, just once it's f'n amazing. Good luck!
Go to slponline.com, click on 98-02 f-body, exhaust components, click on headers, on left side of page will be INSTRUCTION tab, click that and you should be set. I know you are installing pacesetters, but the install is pretty much the same for all header brands!
Formerly darynC-10/23/10
i see its VERY easy if you take your coil pack rack off . it would also be easy to use a ratchet wrich to get the bolts started & in an extra set of hands would be helpful too!!!
