relocating battery v cutoff switch location
so Im considering relocating my battery to the truck of my car. To meet NHRA rules I need to have a master shutoff switch outside the vehicle. I was wondering if anyone here has done this, and if I could get pictures for ideas.
This is my daily driver so I'd rather not have a massive switch in my taillight or rear bumper.
I was thinking of putting it in the spot for my license plate, but off to the side.
Also with the relocation what did you guys do when you got the cable to the front? Did you run new wire to the fuse block/alternator or splice it into the original wiring somehow?
Would 1 gauge cable be good enough to run this distance? Or would that be too small?
Thanks for your input guys.
i mean when you are running new cables you need to run one from the alternator to the battery, not from the alternator to the accessory side
keep the things that draw power on one side of the switch and things that make power on the other side.. then when you disconnect the switch the car will shut off properly
