Who has/had stock engine with no cats?
stock engine without cats
Jim
I have experienced exactly the same problem.
My engine is stock but my exhaust system uses S&P headers
with 3 in. stainless steel pipe to the silencers via flanged connectors
(either straight through,for track,or a high flow cat,for road test emmisions.)
I have had to fit the cats permanently as it was unpleasant to drive for any distance.
I would be interested to hear if there is anything that can be done with tuning to lean out the mixture as it does seem to be unburnt gasses from a rich mixture. Or is it something else ?
I also found little improvement in performance with the straight through pipes fitted. Hope someone who has overcome this problem can advise best course of action.
Trevor
Replica Cobra 2002 LS1/T56
Trevor
Originally Posted by BIG_MIKE2005
Yea, if you remove the cats you will smell the spent & unspent fuel fumes. Just part of the modding game. You can really smell it with LT's & ORY.
Nah, I've got a friend who I'm trying to help resolve this problem. He had the ORY with his stock cam and he said it smelled, but didn't smoke. Now he switched to a Vinci 060 cam...
DUR @ .004" 290*/ 294*
DUR @ .050" 228*/ 232*
LIFT .551 / .551
OVERLAP 68*
LSA 112*
... and it's smoking out the tips. Other threads seem to be indicating it's merely a result of the ORY. But since he says "It did smell, but not smoke" with the stock cam, we're still wondering if the tuning is off at idle, or if it's a mechanical issue.
LIFT .551 / .551
OVERLAP 68*
LSA 112*
Moderator
I ran with gutted cats for a year or three, it had a smell
to it but not "obnoxious" or overly noxious. It smelled
like happy motor to me. But instead of soot at the tips
it became more like tar.
With the headers it's stankier because the mixture is
swinging wider (going by idle O2 volts).
LIFT .551 / .551
OVERLAP 68*
LSA 112*
LIFT .551 / .551
OVERLAP 68*
LSA 112*
Has he gotten it dyno tuned?
I also get some soot on my tips.
