please help stock cam
Old 09-29-2007, 05:51 PM
Big Bird WS6's Avatar
Default please help stock cam
i have a 2002 trans am
if i put the 98-00 cam in my car what kind of hp gain will i see.
local guy has one that he is just giving me?
Old 09-29-2007, 08:40 PM
hotrod7687's Avatar
Honestly, I dont think it would be worth the effort. That cam isnt much bigger than your stock cam.
For all the work thats involved, I would just wait until you can afford one that will really help.
Old 09-29-2007, 08:50 PM
Reject's Avatar
that would make no sence to go from stock to stock. if you wanted to keep the car feeling like it had a stock cam but alittle extra power the GT2-3 cam would be awsome, retains the stock idle and everything but pulls like a ls6 cam on steriods!
Old 09-29-2007, 09:31 PM
Restricted User
socmguy's Avatar
NOT worth the work. get it and make it into a lamp.
Old 09-29-2007, 09:54 PM
JScamaro's Avatar
Too much work for little to no gain.
Old 09-30-2007, 12:03 AM
Sunset'01Z's Avatar
you wont gain a damn thing from it. i know they are bigger but only by a few degrees. if you want to upgrade your cam, try a tr224 or something, dont waste your time on something like that.
Old 09-30-2007, 10:59 AM
Tainted's Avatar
jack ****, the cams difference are so small I doubt you'd even gain 5rwhp from the swap. get a nice MS4 or something
Old 10-01-2007, 05:39 PM
Reject's Avatar
meh i had the ms4 went down to a 226, will probably go to a gt2-3 cam
Old 10-01-2007, 06:11 PM
Tainted's Avatar
well you should be a professional by now changing uot all those cams huh?
Old 10-01-2007, 07:58 PM
Reject's Avatar
yup got it done in about 2.5 hours, how's your car
Old 10-01-2007, 09:10 PM
5_02ls1's Avatar
465 to 498 thats a big difference ill argue it to anyone.....as easy as a cam swap is i would do it it will be like puttin on 1.8 rockers....if the cam is free......you may not feel alot of power difference but ill bet you will e/t better at the track.....id say its worth 10rwhp......hell the ls6 is like a 20 gain over the 98-00 cammed cars.......id do it if its free the swap aint that bad at all.......you will also gain a couple degrees of duration.....
Old 10-02-2007, 10:14 AM
lilbuddy1587's Avatar
